Old 01-07-2018, 09:21 PM
sabrecruz sabrecruz is offline
Default Cub cadet 71 restoration
Hi, I'm new to this, so here goes
I'm restoring my 1966 71 cub. The bolts on my seat spring are worn. I was looking for IH stamped bolts, but am having a hard time finding them. I'm thinking of going stainless. Anybody have any pros or cons on stainless?
Old 01-07-2018, 11:44 PM
Welcome to OCC.
No comment on my end on what you use for fasteners. Your tractor, your money.
But please start a thread when you start your restore. We here enjoy watching others progress on their projects.
Many here have done restorations, and documented them in a thread. Pictures are a plus, as we are picture hogs...
One that comes to mind, you may be interested in, was Tim's (Olds) restoration of his grandads 100.
I did an original a few years back. A link to the thread is on the bottom.
Again welcome, you will find a wealth of knowledge here, and some great folks as well.
Old 01-08-2018, 07:07 AM
Here are a few pictures of the 71(I hope). The easy part is done! Now if I can remember how it all goes back together.
Old 01-08-2018, 07:37 AM
First, welcome to OCC.....
IF, you are concerned about being 100% OEM restoration accurate on your bolts and fasteners, it may take a lot of time finding IH embossed bolts.
IH did NOT use Stainless Steel hardware.
Thus, you will have to decide on being correct or use stainless steel.
Old 01-08-2018, 08:14 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Welcome to OCC and thanks for the pix. Looks like a nice tractor to start with!
Regarding IH bolts...there's plenty of 'em on Ebay... you may have to clean them up some (or not) but there's always some there.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-08-2018, 10:44 AM
Bamafan Bamafan is offline
Inactive Member
As John said the IH bolts can be found if you do some searching.
I am in the process of restoring a 100 and i'm going to use the original bolts that came out of it. Good luck and as others have said these guys are a great help, so don't be afraid to ask.
[B]Larry[/B]
Old 01-09-2018, 12:44 AM
johncub7172's Avatar
I'll take the IH monogram/stamped IH bolts if you decide to go with the softer, stainless steel metal bolts!
Welcome!
Old 02-04-2018, 08:30 PM
Default cub cadet 71 restoration
Hi all! My project is at a slight standstill. i want to replace the axles seals, cause one side is leaking. I have had trouble finding them, but alas, i think I found them. I have talked to a few people who have used Sherwin Williams paint and were very happy with the results. I guess regardless of what i use, itll turn out nice. I'm hoping to start putting some progress pics up soon.
I am going to replace the front tires also. I wish somebody had the design like the original tires Does anybody have any tire preference for a replacement? all this thinking is making me thirsty
Old 02-04-2018, 10:42 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
If the axle seals are leaking the axle bushings may be worn too! I am in the process of restoring a 72. I replaced the bushings and seals. I bought the parts from Mcmaster-Carr.
I tried Sherwin -Williams paint and hated it! Went to API and had them mix the correct color using acrylic enamel. I should point out that I had most of the tractor powder coated but certain items (engine, transmission) had to be wet painted. Happy, happy, happy!
The original style tires are no longer available but I did find some Firestones that had a similar tread design through Miller Tire.
Queen Of The Quietlines!
