Old 02-13-2018, 08:34 PM
Inactive Member
Default 1772 broken engine cradle
I was changing out the driveline on my 1772, and I found a broken bolt that holds the cradle to the frame... I also found this under the radiator!
File Type: jpg 9B5B72B9-EF92-4549-998F-D02A41F164CC.jpg (18.2 KB, 158 views)
Old 02-13-2018, 08:37 PM
Inactive Member
Here’s the new CV style driveline. Many thanks to Jeff inPA!
File Type: jpg AF8D8399-8513-4EE4-8144-AE59C91B6B0E.jpg (18.4 KB, 157 views)
Old 02-13-2018, 10:34 PM
There was a guy on here not long ago (I didn't think it was you Darrel, but maybe it was) who was having some kind of issue with either the radiator, or the engine vibrating or the fan hitting the radiator. Wish I could remember. Perhaps this was his problem as well. Something to look out for in the future for sure. I don't have a diesel tractor (yet) but I have never seen any that I've worked on, or anyone on here, mention one breaking there before.
Driveline looks good!
Old 02-14-2018, 06:11 AM
Originally Posted by IliketheRedcubs View Post
Changing out the driveline on my 1772 I found a broken bolt that holds the cradle to the frame... also found this under the radiator!
Off to the welder we go.
Old 02-14-2018, 07:51 AM
Wow Darrell, what did the po do with that tractor? I'm not sure what would cause that issue.
That driveline sure looks purdy. Let us know how smooth it is once you get it back together.
Old 02-14-2018, 09:03 AM
Like we used to say back in the 60's
Man like "bad vibrations"
3 cylinders have bad vibrations.
Even numbers are always better
two's a company threes a crowd.
odd man out
no 3 on a match, etc.
Old 02-14-2018, 12:01 PM
Inactive Member
I can't help but wonder if the broken bolt on the cradle caused this failure... I think Ole George is right though... bad vibrations! LOL!
What is surprising though... even though by nature these 3 cylinder diesels vibrate pretty bad, this one wasn't! There was no extra vibration anywhere, the radiator, nor the rear end yet there there was a lot wrong with it! Broken bolt on the cradle, broken weld and a stripped out spline coupler and worn drive shaft... My buddy who's a very good welder, is coming on Thursday. He'll patch her up and then she'll be singing pretty!
Old 02-15-2018, 10:12 AM
V30crewcab V30crewcab is offline
odd man out
I got a 2cyl kubota engine that makes that 3cyl look smooth as glass!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-15-2018, 10:49 AM
mickb72 mickb72 is offline
All those broken wore out parts were taking out the vibes. Mike
