Old 03-28-2018, 05:00 PM
Marko141's Avatar
Marko141 Marko141 is offline
Default 127 tiller
Decided to take off the snow blower from the 127 and start hooking up the tiller. This will be my first experience with tilling with this cub cadet so bear with me. I have the gear box attacked, hooked all the arms from the tiller to the gear box without an issue. And yes the mule drive. I did find that the metal rod/bolt coming out of my 3 pt was only intended to be used with sleeve hitch that was on the tractor. So I need to find the needed one or make one. Part number is 485-294-R1. If someone knows where to get one let me know, Cub Cadet says it is no longer available.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 03-28-2018, 05:02 PM
sir_lancealot sir_lancealot is offline
User JeffInPA makes them. Link is at the top of the page. "Parts by Jeff"
Old 03-28-2018, 08:01 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Turn the shaft 90 degrees and drill another 3/16 hole so it is vertical ,plows are horizontal just turn put a hole for cotter pin and use
Old 03-28-2018, 10:23 PM
Marko141's Avatar
That's more than likely what I will end up doing, someone actually made this one as well after I looked at. Someone cut the head off a big bolt and drilled the holes. May just go do the same thing.
Old 03-28-2018, 10:28 PM
Marko141's Avatar
Just a photo of how it sits now. Looks sharp, can't wait to use it.
Old 03-29-2018, 04:39 PM
Yep you need a different lift pin. Tillers are fun!
