Old 04-05-2018, 05:37 PM
Captainmorgan Captainmorgan is offline
Default I1046 wiring diagram
I guess this needs to be in this section. I have a 2007 i1046. I really like the mower, but it has recently been melting it's 20 amp fuse, but not blowing it. If the fuse is pulled out it will not turn over, the pto clutch will mot engage, and the headlights will not work. I can putt it out after it starts and it will keep running, but the PTO and lights do not work. I was hoping that someone here would have a wiring diagram and/or some suggestions. Model number 17AF9BKH710
Old 04-05-2018, 06:58 PM
I don't have a Wiring Diagram in my Library on the I1046.
Your condition sounds like you have some sort of "high resistance" connection. I would strongly suggest, that you look at the "Fuse Holder" and the wires connected to it. IF......you see any sort of burning or discoloration, replace any/all of of anything discolored.
Old 04-10-2018, 11:36 AM
delikocc delikocc is offline
Schematic Attached
Old 04-19-2018, 12:15 AM
Originally Posted by delikocc View Post
Schematic Attached
Awesome thank you.
Old 04-19-2018, 07:51 AM
Clean or replace the fuse holder, sounds like it is corroded, creating high resistance, thus heat
Old 04-19-2018, 08:01 AM
Bamafan Bamafan is offline
Inactive Member
I agree with OL'George. I just went through the same thing with a LT1045. replaced the fuse holder and problem solved.
[B]Larry[/B]
Old 04-17-2026, 07:08 AM
Suthn2 Suthn2 is offline
Schematic Attached
Thank you much for the wiring schematics, as I have looking everywhere until I came across your Bulletin board.
Old 09-24-2022, 12:14 AM
Jayel Jayel is offline
Thanks for the wiring diagram. I have also downloaded it and I hope it will be very useful in solving my ignition/start switch problem.
Old 10-05-2025, 05:15 PM
adrianbrecely adrianbrecely is offline
I have the same symptoms on a I1046 - thanks for the advise and wiring diagram guys
Old 03-28-2026, 02:46 PM
Ozkiwi Ozkiwi is offline
Default Not sure if it's helpful here
I have managed to locate and download the Owners Manual and the Parts Manual for the Cub Cadet I1046. They are both in PDF Format. If anyone wants them sing out and I'm happy to email them.
Steve aka Ozkiwi
Tags
diagram, fuse, i1046, melt, wiring
