Old 07-01-2010, 07:18 AM
gazoriginal gazoriginal is offline
Default removing paint?
i have a CCO, the previous owner tried to paint it with a yellow spray can. they used bright yellow(pretty ugly). is there a way i can try to get off this spray paint without harming the original paint. i wanted to try hitting it with the pressure washer, but thought i would post here first to see if that was a bad idea. thanks
Old 07-01-2010, 07:59 AM
Mr.Jeffro Mr.Jeffro is offline
Default Paint Removal
Gazoriginal,
In the past I have use a spray chemical to remove paint and it may work for you with the ugly yellow you're trying to remove.
I have used "brake clean" in the red can that can be purchased this from your local autoparts store. Orginially, this spray substance was used for carpet and uphostry clean; however, many have found that it really works great for cleaning grease and other crap off of parts. It will soften and begin to disolve the paint and you can wipe or scrape the paint off. I used to take most the paint off and then sand with an electric sander. It worked well.
Warning - use this stuff in a well ventilated area and use eye protection. This stuff can really knock you off your feet with out proper ventilation.
I hope this helps.
Jeff
Old 07-01-2010, 08:05 AM
The whole thing pretty-much depends on how well they preped the surface before they spray bombed it.
Old 07-01-2010, 08:42 AM
i dont think they did any kind of prep work. in a couple of spots you can see where the paint is starting to come off. i know they didn't use any kind of primer. taking a sander to it, would that take off the original paint too? i was hoping to leave that intact.
Old 07-01-2010, 09:16 AM
Yes, a sander will take off the original paint too...it'll take everything off right down to bare metal. If the paint is fairly fresh, lacquer thinner might take it off, but test in an inconspicuous spot to make sure it doesn't take off the original paint, too.
Old 07-01-2010, 10:46 AM
Little General Little General is offline
Try easy off oven cleaner. It took all the paint off my Rancheros engine, I was trying to remove grease, it worked.
Old 07-01-2010, 11:35 AM
johncub7172's Avatar
Yes, make sure you use eye protection. 2 weeks ago I was cleaning my tiller with simmilar stuff.....right in my eye! Believe me, it will knock you to the ground...worse than than when I got squirted in my eye with krazy glue. The spray dried my eye out instantly. Its a wonder I still have both eyes.
Tags
cco, original, paint, spray
