Old 04-28-2018, 10:19 PM
Rodster Rodster is offline
Default 1864 'Improvement'
Being the 1864 has a plastic hood and sides, a few years ago I decided to 'improve' mine in order to try to keep the temperature down under the hood.
I figured less heat would extend the life of the plastic so I wrapped the muffler in exhaust wrap.
Maybe it worked but pretty sure it was the cause of the recent muffler failure.
When I removed the wrap, it looked like the metal had scaled and weakened probably from the increased heat the wrap held in.
Oh well, I get a new muffler out of it and like someone once said, when you make a mistake while doing things yourself, you are just paying for education!
Old 04-29-2018, 08:37 AM
john hall's Avatar
Not exactly a horrible idea concerning protecting the plastic. Like you said, the muffler wasn't designed to hold in that much heat evidently. Thanks for sharing, that's how we learn what works and what doesn't. So I have to ask, does after all this time, your plastic appear to be in better shape than most of that style?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-30-2018, 12:50 AM
Yea, at the time I thought it was a great idea.
I'm thinking it had to help somewhat but I also open the hood to let the heat escape as soon as I shut off the tractor. Since half of the one attaching pin on the side panel is broken, I usually remove that too since it's easy to get off.
I would say the plastic probably looks better than your average 1864 but my tractor is just used for mowing so it leads a pretty easy life.
This is the most recent picture of the plastic.
Old 04-30-2018, 09:15 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
That thing looks brand new! Cherry machine
1- 1200 in pieces
1- 1864 in pieces
