Has anyone ever replaced the 4x4 shifting components in this model that are located in the passenger-side half shaft? With the nice weather coming, I'm about ready to do it as the humming noise going down the road has me aggravated. I figure I don't have to split the upper ball joint as I have a new wheel hub, factory correct GM parts, rotor, pads, brake line, vac switch off the transfer case, gear oil,.... ect. The computer and motor work as should, as well as the control buttons. Has all disk brakes that I recently replaced all 3 as well as all 3 calipers. The truck is in pretty good condition considering all 18 years of being in the great rust belt. No engine check light!
If you have any tips, that would be great! It seems pretty simple to preform. Off topic, but my friend once had the 1993 Chevy Cyclone? With the super charged 4.3 Vortec. That truck would tear up the 1/4 mile at the track on amature night. Mine is going good with 176.400 miles. thanks |
What humming noise? Sure that it isn't a hub bearing?? I have changed alot of those.
Also if you have never replaced the ball joints check those out closely. Seen many an S10/ blazer on the side of the road when they were a more current model with the top of the wheel buried within the wheel well from Baltimore joint breakage,. Replaced a ton of them too in 20 years spent as an alignment guy. |
The humming noise is coming from the two worn out, special washers between the output shaft of the differential, and the slide gears, I believe. My 4-by always worked. Once in a while I would hear a grinding and clicking noise from under the front end while driving. I had no idea what it could be. My transmission works wonderfully. I soon found out what it was all about this winter when I needed my 4 wheel! I removed that transfer case vac switch and it was frozen like a manual hydro release valve that had been sitting in the rain for years. I could not get the ball to move up or down. So this $16 part caused about $600 worth of parts..... this is why I'm doing the repairs myself. Its in my blood. The vac switch under the battery, and cable are fine. The buttons, computer, motor all work as should. Thank you for suggesting to replace the upper and lower ball joints. Checked on prices and they are pretty inexpensive. I'll just have to grind off those rivets, and get my friend's ball joint fork. |
IF it were a noise bothering me, I surely would change the oil first,,,
My daughters '96 S-10, manual transmission and 4.3 engine, and 4WD was making tranny noise, and was hard to shift. I found the right synthetic oil for the transmission, and changed the oil, about a week of driving later, no noise, and the shifting was easy again. My '95 Suburban always howled a little from the rearend. It got worse at 100,000 miles I changed to synthetic oil, the noise was gone. |
John, the noise isn't coming from those "special washers". I think you're going on a wild goose chase. PM me if you want to discuss it. I've rebuilt a lot of Chevy front ends. And by front ends, I mean the entire axle. Inside and out.
Thanks Jon! I'll shoot you a pm once I get it apart. It is my work truck so I need to get it done this weekend as the weather is going to be good. Picking up the upper and lower ball joints tomorrow. Saturday I will exchange the brake caliper and buy a new one. Thanks for again !
I don't know where you buy your parts.... but I strongly suggest not using "cheap" ball joints. Get Moog or Spicer/Dana. If not, you'll be replacing them again in short order.
