Old 05-06-2018, 08:45 AM
Mcamp Mcamp is offline
Default 2072 trans trouble
I'm working on a 2072 that works great until you work it hard for awhile pulling cat 0 plow, it will lose hyd lift and power steering, the drive power is lower also. It has Hy-tran and a new NAPA filter no change. Could it have a bad pressure relief valve? After it sits and cools down everything works good. Any help is appreciated.
Thanks
Old 05-06-2018, 09:54 AM
CubDieselFan's Avatar
How many hours are on the tractor?
Old 05-06-2018, 10:26 PM
913 hrs, the tractor is very nice cond.
Old 05-06-2018, 10:38 PM
Is the fan still on the driveshaft and is the pump clean on the outside so it can cool?
Old 05-07-2018, 01:37 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
If it's clean and cool, and not whining excessively, I would be looking at the charge pump relief valve. Ignore the non-ported pump pic. The attached image shows the diagram for my thoughts due to your specific symptoms.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-07-2018, 10:41 PM
Yes it is spotless clean and fan is there. No whining. I wondered about the relief valve but never have had one fail that's why I decided to ask for more input. Now to get time off work to dig into it.
Thanks
