Old 05-09-2018, 01:47 PM
bsm2003
Guest
Posts: n/a
Default Differences in Rear-end gearing if any.
Have a 2182 the bolts holding the rear-end to the frame are busted out. Found a cheap 1440 with what appears to be a pristine rear-end (IE-not busted out where the bolts that hold it to the frame are.)
Is the gearing the same for a direct swap? I will be doing the SamMac mods and new gaskets and seals. Just wanting to clarify that the gearing and such are going to be the same. Don't have a problem swapping them out if need be.
Thanks in advance.
Scott
Old 05-09-2018, 01:56 PM
Terry C's Avatar
Terry C Terry C is offline
Thanks in advance.
Scott
Supers are geared different. Not a direct swap.
Rear end braces do wonders
Sam will be along shortly to help, he’s the expert
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-09-2018, 02:28 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The 1440 has a Hydrogear trans and a 2182 has a Sundstrand trans. The reduction housings are different. So I hope you didn't buy it yet.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-09-2018, 02:43 PM
bsm2003
Guest
Posts: n/a
All I really need is the axle housings. They should I hope bolt up to the 2182 housing.
Old 05-09-2018, 02:55 PM
Shrewcub's Avatar
Sorry, I misunderstood. I thought you meant the front mounts. Axle tubes are the same.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 05-09-2018, 03:08 PM
bsm2003
Guest
Posts: n/a
That's what I thought. Just wanted to confirm that was the case.
Thanks.
Scott
Tags
1440, 2182, rear-end, super mods, swap
