Old 05-18-2018, 06:37 PM
mkedzierski's Avatar
mkedzierski mkedzierski is offline
Default Final Drive on XT3 GSX
Anyone know what the final drive ratio is on the XT3? If so, please pass along. Several people would like to know including myself.
Old 05-18-2018, 08:04 PM
Your dealer that your XT3 came from can tell you.
Googleidge it .
Up to 534 and counting...
Old 05-18-2018, 08:15 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I Googlerated it Lew and didn't find the answer easily. I too would call or email. If I needed the final ratio for some reason, I would also like to know the reduction ratio, as they go hand in hand.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-18-2018, 08:29 PM
When I googood it I got the answer.
Old 05-18-2018, 08:37 PM
Shrewcub's Avatar
Care to share?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 05-18-2018, 08:41 PM
Can't tell you...
Old 05-24-2018, 07:09 PM
FYI...Cub Cadet asked the their engineering dept and they responded with a 27.7 to 1 final drive ratio on the XT3.
Old 05-24-2018, 11:25 PM
Terry C's Avatar
Terry C Terry C is offline
What are you and your other concerned citizens going to do with this information?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-25-2018, 12:44 AM
I want to know what the question really is, and the answer.
There is no "final drive" on a Cub Cadet. Not by a tractor standard anyway. If you wanted to be technical, the final drive would be the last reduction before the wheel. But there is one before that "final" reduction.
So, did you originally want to know the total reduction ratio between the hydro and the wheel? Or did you just want to know what the last reduction is?
Is the answer the "engineers" gave the ratio of the R/P? Or the total ratio between the hydro and the tire?
So, I made a quick trip to the parts book. I looked up the trans for an XT3. It shows all the gears, and the tooth count of all of them, minus the pinion gear on the hydro. (Says not available.) But I know the trans in the XT3 is the same as the trans in a 3235, so I looked it up. Low and behold, all part numbers are the same, but that diagram actually lists the gear on the hydro and gives the tooth count. So, in less than 10 min, I now know what the ratio of the hydro to the ring gear is, and the ratio of the ring gear to the "final drive"..... AND.... what the 27.7:1 ratio is that was stated by CCC! And I didn't have to make a phone call, or wait 6 days to get an answer.
Math and reading are so cool.
