Its on the 3rd one since i have had it in not quite 3 years. Maybe i am buying cheap pumps, which one should I buy? Or is there an electric one that would work better?
________________________ Scot |
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
18XX's don't need a fuel pump unless you run the tank low on fuel or use the tractor on steep incline. My pump failed on an 1811 I had so I bypassed it and ran it for 2 or 3 years without any issues.
So i found out it is not the fuel pump, but it won't run unless I squirt fuel into the carb. Fuel hose is not clogged, so it's something in the carb. Suggestions where to start, other than "tear it apart & look for a clog"?
Thanks
Suggestion to start, rebuild kit. If you tear it apart and clean you might get by w/o the kit. Mike
Will a 17hp carb work on it? Neighbor is an old fart that b!tches about everything. Yesterday he was "jokingly" b!tching about the height of my grass, but I know deep down he wasnt joking. Can I run it until I get other fixed?
