Old 07-31-2018, 09:10 AM
samiam44 samiam44 is offline
Default What does a bad bearing sound like K-series?
I'm asking..
Somewhere the motor has gotten a metallic sound. It's toward the front and I had assumed that it was the muffler internal baffling or something failed. But after a few more weeks of cutting grass- it developed a front seal leak. I have a seal and home.. thought I'd change it up. But I'm assuming that a bad bearin g will have noticeable play?
Old 07-31-2018, 09:44 AM
What tractor is this engine in? Trying to determine if the engine has balance gears.
Old 07-31-2018, 10:06 AM
Does it make more of a humming sound?
Old 07-31-2018, 10:13 AM
Unless the engine has a lot of metal rolling around in it, the big ball bearings on the crank never fail. Usually even on a rebuild, you can use them over. Chances a bearing is out are very, very slim.
A "metallic" sound is kind of indifinitive. Squeek, knock, rattle???? Tim might be onto something with the balance gears, but when they go out, I wouldn't describe it as a "metallic" sound. They will rattle and knock. You either need to post a video to YouTube and link it here, or describe it better. Several things can cause noises. I'd say the seal leaking is coincidental. But, anything is possible.
Old 07-31-2018, 11:32 AM
Cam shaft end play
Old 07-31-2018, 12:15 PM
Terry C's Avatar
Terry C Terry C is offline
Cam shaft end play
That’s my vote too.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-31-2018, 12:23 PM
Cam shaft end play
That’s my vote too.
Well, then why wouldn't he describe it as a knock??
Old 07-31-2018, 01:32 PM
I had a motor in a 149 that had a bad crank bearing, and a 129 with the same, was always on the PTO end.
Makes a HmmmmmmHmmmmmmHmmmmmm sound.
