I’m working on this 73 for a friend and the PTO clutch is stuck engaged. I can’t get it to pop out. Any tips or tricks? Or is it disassembly time?
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Is it adjusted properly? I would try mowing with it disengaged and see if it breaks lose on it's own.
The adjustment was too tight, I loosened it up and there’s a good inch between the button and the lever. I mowed with it and it didn’t pop out. I can wiggle it side to side in the “teeth” but it’s not popping out to disengage.
The lever pushes on the button to disengage the PTO, it will never disengage is the lever is an inch away.
With the hand lever in the forward position adjust the rod until there about an 1/8" between the arm and the button on the PTO.
Maybe I need to read up on how these things work. I have never seen one before up close. I assumed with it forward and space released it.
That's a good way to burn the buttons up.......
I've only ever had to do it once and it only took about two minutes to break free, that PTO still works great 5yrs later.
I use a hamma'
