#1. i sold my 123 hydro i kept the snow blower and blade and im looking at buying another vintage model. can anyone tell me what models the blower and blad will fit on ? for example. does an original have the same mounts ? i dont think it does but dont know.
#2 im looking at an original. a 70 a 100 and a 147. pros and cons anyone ? for example. which has better power ect. weaknesses look forward to this info guys thanks. |
I'm not that up on the "OLD" ones, but the 147 should have the largest engine, 14hp Kohler I believe.
I’m not super knowledgeable on the non-qa (Pre-1x4/5 models) attachments. I’m pretty sure the original is an oddball though.
147 will be the biggest and most modern of those options. 70 and 100 are basically the same tractors but the 100 would have had a 10hp engine vs 7hp in the 70. Otherwise they are the same. Original is a 7hp. I’d argue that it’s more of a collector tractor than a worker, but plenty of people use them to work. 147 is hydrostatic and the rest of those are gear drive.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
Your attachment's will fit the 70/100 no problem, they will also fit the 147 but will still have to be bolted on since they're probably not quick attach attachments. The original takes attachments that are specific to it.
70/100 71/102/122/123 72/104/105/124/125 73/106/107/126/127/147
Yeah I guess/ I have all wide frames and QL's and I know that everything is different between them and my son's Original
