Old 11-25-2018, 07:07 PM
Pequeacubs's Avatar
Pequeacubs Pequeacubs is offline
Default Charge pump seal issue on 1811
Hi,looking for some help on my 1811 the charge pump seal pushes out when i move the hydraulics up and down. thanks
107 w/ 75lb IHC wheel weights 3pt. hitch spring assist lift.
1810 w/spring assist and brinly cat.0 3pt hitch w/A frame adapter and sleeve hitch now an 1811 cab and 551 blower
1000
42" spring tip snow dozer blade,qa36a snow thrower,#1 tiller w/1 ext., brinly 10"moldbord, 3pt.cutivator,brinly disk,#1 trailer #4 trailer, 2 sets of Ih weights
windbreaker soft cab,qa42" snow thrower
my grand fathers 67' j.d.110h with brass tag 6 way snow/dozer blade
67' WH lawn ranger
Old 11-25-2018, 07:53 PM
Time to change the SU-9008000-6201 seal.
Up to 534 and counting...
Old 11-26-2018, 05:40 AM
Oak Oak is online now
Here are 2 more options.
https://www.napaonline.com/en/p/NOS6904?interchange=1
https://www.motionindustries.com/pro...p?sku=00613212
Old 11-26-2018, 09:52 AM
mhbtsc mhbtsc is offline
Are you saying that using the hydraulics pushes the seal out? Then what? Do you put it back in?
Old 12-01-2018, 02:19 PM
Pequeacubs's Avatar
yes i push it back in. i put a new seal in it at the end of last winter. i did use the oem part#
1000
67' WH lawn ranger
Old 12-01-2018, 02:21 PM
I wonder if its not venting and building pressure?
