Old 12-25-2018, 08:34 PM
grasstomud grasstomud is offline
Default XT3 - Power Steering Problem
Good evening.
I am new to the forum, but been on a few for other things.
I have a XT3 Cub that was given to me in a house purchase deal and absolutely love it. It came with a 42 3 stage blower setup from the previous owner special ordered that way. I used it few times this fall driving around, but recently I went out to blow and the Power steering is not working.
The battery is good and all else works except that. So....What should I start with first, that one of you guys can direct me to trouble shoot. Has anyone had a problem that I should be aware?
Man the machine turns on a dime with it active but when its not its a bullll.... Sorry for story time but help me out so I can get going. Also 75hrs 3 or 2 years old.
Thanks Everyone
Old 12-25-2018, 09:13 PM
john hall's Avatar
First off, you posted in the engine section, hopefully a moderator will move this to the correct section so you will get better views.
Second, is this still under warranty by chance? I'd call my dealer first thing in the morning. if nothing else maybe they have heard of the problem and can point you in the right direction.
There are a few folks here running newer machines. Unfortunately most of us are tinkering on the machines that are in excess of 20 years old. Only reason I point that out is the knowledge base on the newer equipment is not near as vast as what it is on the old stuff. Not knocking your newer machine, think there were a couple guys that bought the same one this past summer.
So assuming your machine is not under warranty, tell us a little more. Is the steering electric? If so start chasing power with a test light/meter. May be as simple as a blown fuse or broken wire.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-25-2018, 09:22 PM
ejl6658 ejl6658 is offline
There are many vintages of the xt3 but I think most have the electronic power steering. Problem could be as simple as a blown fuse. I would start by looking at yours owners manual if you have one or download one and see if it calls out a fuse for the EPS.
Old 12-25-2018, 09:51 PM
Thank you for the replies.... Sorry for the wrong area... i will get into some trouble shooting soon. i will indeed look into warranty info this week.
Thanks again guys....
Old 01-13-2019, 07:00 AM
rudedawg's Avatar
rudedawg rudedawg is offline
Just curious as to what you found with the eps and also if a dealer honored any wty. since you are not the original owner. As a rule of thumb Cub wty. is not transferable to a 2nd party but you may get lucky.
Old 10-27-2020, 03:40 PM
Hoagie Hoagie is offline
Angry cub cadet power steering problem
I have a cub cade LGTX 1050 with EPS. I only have 225 hours on it when it quit working. I can't find anyone who can work on it and cannot find any information on line to troubleshoot it. CAn anyone help?
