Old 02-21-2019, 12:52 PM
RC12345 RC12345 is offline
Default 126 stuck PTO bearing and collar
Hello, I'm wondering if anyone can help me with the stuck collar and PTO bearing. One youtube said to tap the collar counter-clockwise but a post said to tap it clock-wise. Neither are working. I've tried PB Blaster and WD40 but it's on tight. I'm about to resort to the angle grinder and a cutoff wheel. Any better ideas?
Thanks
Old 02-21-2019, 01:00 PM
cooperino's Avatar
First off.. Welcome to OCC!
Are you trying to remove the PTO assembly from shaft?
Old 02-21-2019, 01:01 PM
Try both ways.
it could be iocked on either way, Needs to be a rather sharp rap, not just a love tap
Old 02-21-2019, 09:39 PM
sawdustdad's Avatar
It is supposed to be tightened by tapping it counter-clockwise, same direction as the rotation, looking at the PTO. So, theoretically, it should be loosened by tapping it clockwise. With about a 3/16 drift, and a 16 oz or better hammer. Give it a good whack.
Caveat is that it is probably just as often tightened the other direction, so if it doesn't come loose CW, give it another whack CCW. Good luck!
And welcome to OCC!
Oh, the reason it is tightened CCW is because with CCW rotation, force on the PTO is CW (resistance to rotation) which would tend to tighten the bearing inside the eccentric lock collar.
Old 02-21-2019, 09:48 PM
AndrewNoyes AndrewNoyes is offline
Sawdustdad,
Isn't it normally tightening in use, in the direction resisting rotation? So wouldn't that imply tap in the direction of rotation (against the way it would be experiencing force while in use) to loosen? Or am I mixed up?
Regards,
Andy
Old 02-21-2019, 10:05 PM
mortten mortten is offline
Did you remove the set screw holding the collar to the shaft? Andy, the centrifugal force is thightening the collar to the bearing, not the shaft.
Doug
QA-36A
42" blade
Old 02-22-2019, 09:46 AM
sawdustdad's Avatar
Originally Posted by AndrewNoyes View Post
Sawdustdad,
Regards,
Andy
The service manual says to tighten the lock collar on installation by tapping it in the same direction as rotation, or CCW.
In reality, it seems to work most of the time regardless of which way it is tightened on installation as I've found them both ways. It does have a set screw as well.
Every time I've removed one, it's a guess which way to drive it to loosen it. I try CW first, then if that doesn't work, CCW.
