I'm stuck at the point that I need to remove the speed control lever on one of my 129s. One came off easily, the other is stuck. I'm considering drilling and tapping the top center of the lever's hub to use a bolt threaded down toward the splined shaft to drive the lever off the shaft. Anyone try this? Might try a small hole at first to provide a better supply of penetrating oil to the joint. Then drill out larger and tap if needed.
I think the drilling and tapping would work. The problem I see is getting the hole drilled completely down through the handle to be able to thread it completely. What I mean is, if the inside of the handle is sitting flush on the top of the shaft, the tip of your drill bit will hit the shaft before you are all the way through the handle. How will you be able to run threads all the way down?
Since you don't care about the handle you could try using a dremel tool to cut a slit in the handle parallel to the shaft and split it with a chisel. |
The shafts are hollow, about 3/8" ID IIRC
If that is true then you can put a 1/4" rod from the bottom and hit it off.
Not hollow. But I measured the distance from the set screw groove to the tip of the shaft. The hole in the handle goes much beyond the set screw. So drilling would be possible.
I drilled a hole in the top and used a puller. Splines were shot so when I put it back on I drilled all the way through it where the set screw was and tapped it.
