Old 05-25-2019, 08:28 AM
-Matt -Matt is offline
Default Groaning and Sticking 149 Hydro
Hi, all.
I suspect a problem with the transmission in my 149. Here are the symptoms...
1. Groaning sound especially audible after turning off. A fellow forum member (Userj8670) had posted a video some time back that is EXACTLY what I'm hearing.
2. Lots of resistance in the Speed Control Lever (both directions).
3. Speed Control Lever does not fully return to neutral when break is depressed.
Prior to all of this, I made the mistake of pushing the tractor 3 feet back and 3 feet forward (to address another issue) WITHOUT engaging the release lever. (I know-- I'm really quite new to this!)
Not sure if it is significant diagnostically, but I think I may have intermittently achieved some elimination of the sound when applying pressure (or otherwise jiggling) various parts of the cam assembly.
So I have a few initial questions:
1. Am I risking doing more damage by using the tractor in its current state (temporarily)?
2. Are there any "quick fixes" worth trying? (I'm imagining some variation of "reversing" the rolling back-and-forth thing that may have introduced the problem in the first place, if such a thing is possible.)
3. Is there a particular sequence of steps I should take to diagnose and possibly correct the problem?
Background on me: I am NOT very experienced in mechanical repairs (and so some procedures and lingo may get lost on me), but I am game for taking on projects and repairs. I have always opted for old, well-made things and will put the time into figuring things out to repair and restore them (rather than buying new crap that has to get tossed).
My "shop" is woefully under-equipped-- No jack, no pneumatic tools, no electricity in fact-- you get the picture. I have no pickup truck or trailer to get this thing to a mechanic. I live in Ithaca, NY and have about an acre to mow. So while it's not life-or-death to have this working, it has been really helpful to have. Plus, I really love this machine and want to take good care of it.
I would be grateful for any advice (and/or words of encouragement) from you folks, and hope some day to be in a position to offer help to others. Thanks in advance.
Old 05-25-2019, 09:36 AM
Try adjusting your neutral as per the free downloadable service manual here on OCC.
Also check for sloppy/worn linkages.
Has the oil/filter been changed in a while or ever?
just some easy things off the top of my head
Old 05-25-2019, 10:58 AM
Thanks, Ol' George. I will give this a try. I may not be able to determine how sloppy is too sloppy (not having any good reference points in my experience), but this may become more clear as I tinker around in there.
As for the fluids, the transmission oil and filter was changed last summer, and has probably had no more than 25 hours since then. Fluid and filter will also be on my list of things to do.
Still wondering if Im risking further damage by driving the thing while I try to figure out this problem.
Old 05-25-2019, 11:16 AM
Default Video of the groaning sound...
There was another thread where the author posted a video of the sound his system was making, which is EXACTLY the sound I'm hearing. In the meantime, I'll start with the guidance already provided.
Old 05-25-2019, 11:23 AM
Sounds to me like the linkage needs to be adjusted.
Old 05-25-2019, 03:25 PM
sawdustdad's Avatar
Some groaning and whining is normal with hydrostats, groaning is just whining at low speed.
If she runs OK, run 'er. Cut your grass, etc. Use the speed lever to get to neutral if you have to.
The neutral adjust procedure requires a pair of jack stands and a floor jack to get the rear wheels off the ground while you make the adjustment. Sounds like you might have a problem pulling that off.
What you are hearing is the hydro working while cranking or shutting down because it is not "in neutral."
Try this. Start it up, move the speed control slightly so it does not roll on level ground. Let it sit a minute at full throttle in what you've found to be neutral with the speed control lever. Now without touching the brake pedal or anything else, turn the ignition off.
Next, without touching the brake pedal or the speed lever, try to start it. It should not groan. You are still in neutral. Just not neutral via the brake, but neutral via the speed control.
The brake pedal attempts to center the speed control, but due to wear in the linkage it does not get it done accurately. The neutral adjust procedure fixes that. But plenty of tractors get used every day slightly out of neutral adjustment with no harm done.
Tags
149, hydrostatic, noise, transmission
