Old 05-25-2019, 11:17 PM
joelwcassell joelwcassell is offline
Default 582 Issue
Guys here again for help. I have a IH Cub Cadet 582 that I have been working on. It has an opposed twin Briggs in it. I had it running about a month ago but now have an issue where it won’t run without choke and then only runs about 10 seconds. It has a clear gas line so I can see there is fuel to the carb. I am needing ideas to troubleshoot.
Old 05-25-2019, 11:24 PM
Time for a carb rebuild is what it sounds like to me.
Old 05-25-2019, 11:55 PM
IH1086 IH1086 is offline
X 2 on the carb rebuild. If you don't use it often make sure you run ethanol free gas too.
Old 05-26-2019, 08:41 AM
X 3 for me also.
Old 05-26-2019, 09:22 AM
Tom Dowling Tom Dowling is offline
After you take care of the carb issue since you don't use it often it might be a good idea to shut the gas off and let it run out of gas when you are done using it (don't forget to turn the key off afterward) If there is no fuel in the carb it can't gunk up.
Old 05-26-2019, 12:23 PM
You have a fuel delivery issue as everyone already stated.
You can try taking the clear plastic line off the carb barb/fitting and see if it is pissing a good stream, if yes, then the carb should be attended to as to why the fuel is not getting into the engine.
Just because you see fuel in the line, don't mean it is flowing.
Example would be holding a water bottle to your mouth but not drinking it.
A no flow problem.
FWIW:
I don't like clear plastic fuel lines as most become as hard as a groom on his wedding night.
also in cooler temps, again, the hard line tends to leak.
just my call, your milage will vary.
Now,
on the non ethanol fuel issue.
While I don't like corn squeezing's in my fuel as it is best left for adult beverages.
I am not a fan on non ethanol fuel.
But only because it is not sold in large enough quantities for it to be fresh.
I would like an honest answer from the fuel retailer as to how many gallons they sell and how often they receive deliveries.
My bet at the inflated cost, they sell little of it and what they have is at least over a year old.
Again just my thoughts.
