Old 06-27-2019, 10:51 PM
IHCubCadet147's Avatar
Default Bought a 1450
I just picked up a 1977 1450 with a 44” deck. The guy said he bought it 3 years ago and it has been very reliable, but it does need some work. It seems to run good with no smoke. Everything works. It shakes a lot, but from what I’ve read, some shaking is normal. The motor feels pretty solid.
File Type: jpg 924B7E09-57F1-43C0-97BC-B7A9481169DE.jpg (26.2 KB, 290 views)
File Type: jpg 52381849-F648-41B2-AF6A-7C4E5C8B3C0A.jpg (25.7 KB, 293 views)
File Type: jpg A43B34E5-8A32-4058-8E7A-3DF46C790E2A.jpg (24.1 KB, 289 views)
Old 06-27-2019, 10:55 PM
It needs a good cleaning. The rear has about a quarter inch of dirt on it. When I pulled the air cleaner off, it was full of corn. I’m going to pull the motor and check the tins for mouse nests or other debris.
File Type: jpg E4302809-CED5-4E7C-8F85-C0D7F2774323.jpg (17.8 KB, 286 views)
File Type: jpg 9DD3A92E-0CDD-45BD-AA07-5C437716D169.jpg (25.2 KB, 290 views)
Old 06-28-2019, 05:34 AM
twoton twoton is offline
Good deal! 1450's a nice machine.
Old 06-28-2019, 07:03 AM
sorner's Avatar
sorner sorner is offline
Excess shaking can be bad motor mounts, and/or worn driveline because of worn motor mounts. I put new ones in mine when I had it and it made a world of difference. That coating over the hydro looks like a leak to me.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 06-28-2019, 08:59 AM
Thanks!
I’m going to check the motor mounts and driveshaft. Im most likely keeping this one, so it wouldn’t hurt to replace them anyway. I’m sure the hydro is leaking, but I don’t know where. The engine is also leaking.
Old 06-28-2019, 09:32 AM
sorner's Avatar
If your motor mounts are worn you likely have loose or missing bolts holding the engine to the cradle as well, and if they’re really bad the cradle is probably slapping against the cross member under it. I saw all of this with my 1250. Part of the oil pan was even worn away.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
