Old 07-31-2019, 12:24 PM
CurtCub149 CurtCub149 is offline
Default Cub Cadet 149 - hydro tube question
So I have a 149 where the hydroline continued to leak. So I bought the suggested cub cadet 927-3008 and didn't see a gasket for the line running into the 5/8 nut to 7/8 tube. Anyone have any hints or ideas of what goes between the tube and the nut?
Old 07-31-2019, 02:00 PM
First, welcome to OCC....
There is NO gasket to that connection. There is a brass "compression sleeve" that tightens down against the tube to seal it. See attachment.
Old 08-05-2019, 09:55 PM
Banman Banman is offline
On my 149 I've got the tube style pictured on the left. Does this mean my original tube was replaced?
It looks like both style tubes take the same compression fitting where they enter the sump -- is that correct?
http://cubcadetusedparts.com/Product...8-e0fb02ad29d0
Old 08-06-2019, 07:58 AM
It does NOT matter the style or shape of the tubing. The brass sleeve remains the same.
Old 08-06-2019, 12:03 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Maybe the brass ferrule is worn, distorted, or misaligned. Teflon tape on the threads might stop a small leak.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 08-06-2019, 12:33 PM
Tape or sealant on the threads would do no good as the sealing is done by the ferrule.
A new ferrule can be had at most better/larger HWD stores.
