pick up a 1650 from a guy that his dad bought new. He said it started blowing oil out dip stick it still ran but he parked it couple years ago . would it be a broken ring or some thing else?
Cub cadets models. 123, 1250, 3 -1450, 1650, 782,982 ,1711 |
Start with cleaning crankcase breather and see what you achieve. Are you burning any oil?
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I haven't mess with it yet . Previous owner said that it had been rebuild in the 90's
Has 120 pounds compression .
Crankcase breather is clean
"Rebuilt" has many meanings depending on who is telling the "story" To some, it means it was worked on by someone, having no idea what was done or to what. Or to others, things were cleaned up and repainted, or the carb. or fuel tank was cleaned. Still others, it means something like a engine rebuilt including, but not limited to, boring & honing the cylinder to the next appropriate oversize, turning the crank to the next undersize and fitting the proper bearing or rod replacement. Replacing the valves and seats or reconditioning them. Setting the clearance by the proper method resurfacing the block & head or heads. Etc etc etc. No sense building a watch here, I think you get the idea. Now download the service manual, as it is free here, and go systematically at checking the crankcase breather as to if it is functioning properly. Easy things first. Is the dipstick launching into the hood? or just leaking/slobbering? We need more info and not stupid stuff like "it was rebuilt 30 years ago" Now lets "Giddy up" and do some detective work, before guessing. Please explain how you got #120 of compression, understanding that engine has a compression release? Oh, " and they all ran when parked" ![]() IIRR, they said the titanic was steaming along just fine, even the band was playing,---- just before it sank.
Screwe in compresion tester and crank engine over . Goes right up to 120 pounds . The dip stick moves up down a little when cranking
Take the breather OFF and do the compression test again. See if the Dipstick moves.
