Hello All! My brother has a 1872 that he bought new. Finally he had to do some work on it other than normal maintenance. He pulled the engine to replace a leaking rear seal and when he reinstalled the engine and started it, it ran around ten minutes and started vibrating badly due to both carriage bolts snapping in the coupler on the flywheel. Thought maybe he didnt have them tight enough, got a new coupler and made sure everything was tight and same thing after running around ten minutes. He lives over three hours from me so I cant actually see what it going on. Head said the driveshaft isn't bent. Any help would be appreciated. Thanks, Bill Peden.
imagejpeg_1.jpg |
Something is bent or broke. Can you post some pictures of the shaft and the flex disks?
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
I would think something must be misaligned for that to happen to a new coupler. Did the flex coupler line up pretty easily or was it tough to get bolts aligned? Check the engine mounts. See if the are loose or damaged. When you install it again I would turn by hand and check with a run out gauge before running
My bet is that he got #10 and #13 installed 90 degrees off.
Had not thought of that. But yeah. That would certainly do it. You mean like bolted solid together, Right?
Wouldn't that be 90*?? either way bolted directly would do that.
Yep, I was 1/2 asleep when I posted that. 90 degrees it is. Went back and corrected it.
I agree with Sam. Get him to send a picture next time he gets it back together. The front and back.
