I just picked up a 1535. Has a 3 speed with creeper. PO said he just reglued the flywheel magnets and it still has no spark. Hoping he just glued them out of sequence and it will be an easy fix. Has a Kohler Magnum 15 (derated M18) It's in really good shape with low hours. Should be a fun tractor.
Current: 102 122 SZ60 Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265 |
Flywheel magnets have nothing to do with spark. The Mag has a magneto ignition, it fires both cylinders at the same time. You have one of two problems, a bad mag or a problem with the kill circuit.
Good to know. Hopefully it's in the kill circuit. If not, I have a good mag from a 1420 that I can try.
That is a nice tractor, I wish you good luck with it.
Nice low hour tractor, congrats!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
That is a great looking machine and those are pretty rare too. Keep us posted on the progress.
I'd also check to make sure that the PO gapped the magneto properly.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
The magnets on inside of flywheel for stator charging did have problems in a number of different models with coming unglued. These magnets have nothing to do with spark. As Sam said. I would be looking at the kill wire circuit. If its grounded, you wont get spark
was replying for OP vs. Sam. And yeah, basically all the KT/Mag engines had a problem with that. Don't know how widespread it was outside of those, but I'd assume kohler used the same stuff to glue them in on all of their engines.
