Hello all,
I just purchased a 149. Seems the engine wants to jump out of garden tractor. Does anyone know the part numbers of the bolts? Also how hard is this job going to be? I've already dropped the deck, the mule drive, and the pan covering the oil? |
If you grab the engine and shake it, is it physically loose? Its not really a difficult job to replace the bolts, but if it was loose you need to look for other damage that may have occurred. Do you have some close up pics of the mounting, drive shaft, etc
As far as part numbers do. You can just match up bolts at local hardware store
Cooperino,
(“If you grab the engine and shake it, is it physically loose?”) Do you see the irony here, between your post listed above and your avatar picture? “Cub Cadet Makes It, Kohler Shakes It” Little morning humor!
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer |
If the motor had an aluminum pan it had the tendency to have stripped bolt holes.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
The 4 bolts are 3/8 x 1" coarse thread.
I would use grade 5 You will have to raise the front of the tractor to full tilt the axle right and then left in order to access the two front bolts. |
Nice find on the 149.
Are you going to do a full restore, or leave it as is?
Thank you!
Would you do lock washers or locktite? Or both?
