Figured I'd start a new thread since the question asked in the topic of my other one was already answered and I didn't want to stray way off topic. I'm sure I'll probably have other questions so left the topic kinda vague.
Anyway, as I said in my other post, I just got a QA-42A for my 147. It was set up for a wide frame tractor when I got it so I had to set it up for my narrow frame. That went smoothly, but now I have an issue with the upper links not clearing the sides of the front of the tractor (see attached image.) The links are angled inward when installed. I also understand that these are the v shaped links that are actually for a QA-42B but have also read that that shouldn't be an issue. I'm thinking the mounting pins should be longer to accommodate a spacer but want to make sure I'm not missing something before taking everything apart again and trying to replace them. Thanks again in advance! Adam. |
I found this image online. Is this how it should be?
YES, the "curved" upper links on the QA-42B are/were designed specifically for the Cub Cadet 82 Series Tractors.
I would recommend, getting the correct upper links for your application. In the Implement Technical Library Section, there is a link to the QA-XX-A Owners Manual. See Link: Owners Manual.
Thanks for the replies. I do have the manual but its pretty vague on what is involved in switching from wide frame to narrow.
I can make straight upper links if necessary, but I'm not sure how that would help with the clearance issue with the side of the tractor's front end (circled in blue.) There is only about 1/16" with the lift lowered. |
make new bars and put about 1/4" offset in them on tractor end
