On my 2284 the only way I can get reasonable reverse speed is to adjust cam pivot bracket way low. Service bulletin says flush with top of washer over the slot. It was already lower and would barely back up sometimes. After adjusting to get decent speed I adjusted connecting rod to neutral of rear and the dash. Now it has full forward speed with lever 2/3 the way up. Linkages and pins look great. The trunion looks too good. No wear as in maybe replaced? I went ahead and changed springs and buttons. Also 1 ball joint appears replaced. Any ideas as to
the odd adjustment or just run as is?
Also there are 2 holes for the linkage, which one is correct?
I would move it to the top hole in the cam plate, see if it makes a difference.
So I spent the evening trying to get the right hand brake pedal unstuck--its still stuck. Wish I would have seen this before I put the fuel tank back in. Hot wrench would have helped.
Did I read you correctly that you stated that one of the ball joints appeared to have been replaced?
Just a thought... Is it possible that the connecting rod needs some adjustment?
Alan Basket Cases: 129, 1450 sold, 1650 125: 48" Mower Deck, Windbreaker Cab 127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade 147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings |
I adjusted that as well. Going to start fresh by moving the connecting rod to the other hole and see if that improves things. As it is I get full travel in forward but still not in reverse. Given some of the other things I have found on this machine, it may have been bolted together wrong at some point.
