Old 03-08-2020, 09:31 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Delco Starter/Generator
Would anyone know the nut size that fit the field coil lugs that go through the Delco case? I have lost one and can't match at the hardware. I have googled and searched the forum but came up empty. Thanks, and have a great day.
Bob
Old 03-08-2020, 10:17 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Bob
12-24...... I believe you were talking about the nuts for wire hook-up, correct?
Plow blade
#2 Cart
QA36 snowthower
Old 03-08-2020, 10:28 PM
AND, 12-24 is not a common nut,
so you might have to try multiple hwd.
stores.
Old 03-09-2020, 07:34 AM
stores.
Not impossible, but hard to find. IIRC, that is also a Brass Nut too.
Old 03-09-2020, 09:20 AM
Mr Bob's Avatar
Default Delco Generator/Starter
Thanks for all your replies and info. Will start looking at different hardware stores. Does the nut have to be brass? Have a great day.
Bob
Old 03-09-2020, 11:44 AM
cooperino's Avatar
Bob
It was made from brass as to strip out the nut before the stud would be harmed thus saving you the headache of opening up the S/G to replace..It was probably also brass so it would not corrode and rust as quickly being exposed. It doesn't have to be brass to function, but be careful not to over tighten if its made from something else
