I just read this in another post....
"Cub Cadet did not start putting KT-17 Series II until serial number 726,125>." My 782 tractor serial number is 2050601U731511 The engine has a tag but difficult to read: Serial #1402336 Engine Spec 24302 What do I have? |
![]() Quote:
Sounds like you just got lucky..... According to Tractor Data the 2 series KT-17 began at engine spec # 24,300. You are three away from the crap. To be sure, I would see what others here have to say!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Yes...That's what I thought, but I wanted to be sure. It sure does run nice for a 40 year old motor!
That is cool that you got a series II. Welcome to Only Cub Cadets.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
![]() Quote:
![]() Shoot us a pix of the oil filter area of the engine if it has one, specifically the area where the oil pressure sender is. if it has a sender, or a pipe plug it is not a series I Cooling shrouds with numbers ,oil filler plugs/caps, mean nothing as all interchange, so anything could of been changed, but the block will tell what it is. It could even be MAGNUM if it has no ignition coil. ![]() |
It does have an ignition coil......But I do not see an oil filter....but not sure where to look.
Also, can someone tell me where the voltage regulator is located? Here is a quick video of the engine to show how I had to jump out the coil to get it running. https://images44.fotki.com/v1644/pho...6321-video.mp4 |
Here are two better videos of the engine
https://images12.fotki.com/v1667/pho...0637-video.mp4 https://images12.fotki.com/v1667/pho...0639-video.mp4 |
