Old 06-16-2020, 10:37 AM
ChristopherCT ChristopherCT is offline
Default Can the S/G produce 115v from its 12v?
I am adding to this thread because it seems like some smart folk have already contributed to it. And my question is electrical.
I am a very cheap and resourceful New Englander. I recently bought my first CC, and it is a 1972 #129. Ive got it running quite well now, and charging its new battery reliably. My "new to me" neglected home came with a bunch or large and small solar inverters, plus a plug-in electric chainsaw. I DO need a chainsaw, and I don't feel like buying a gas one right now. So I am wondering:
With a strong charge output, can I "jump off" my battery to a small inverter and then run a 115v accesory? Could I then park the CC at idle, and run my chainsaw from it? I will admit that my starter/gen looks original and I it might need a rebuild some time. But it doesn't whine or rattle or anything. I AM wondering if using the original starter/gen is a foolish idea due to stress created. The main engine was replaced with a 1991, but the starter looks original.
Any and all comments are appreciated! -Christopher
Old 06-16-2020, 11:11 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Your battery will put out maybe 200 amps and its amp-hour rating might be 10. Divide 10 by 200 and we get .05 hours or 3 minutes. If you have a 1200 watt inverter that would probably power an electric chainsaw so maybe you could run it for 3 minutes. Your generator will not keep the battery charged at that rate. Think of the generator as a trickle charger at maybe 10 or 20 amps. You could probably trim a few limbs before the battery dies.
Please try it and let us know what happens, or you could just borrow a real chainsaw and cut all day with it.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 06-16-2020, 11:50 AM
The S/G puts out 15 Amps at Maximum. With that in mind, you could run and A/C inverter with a maximum load of 180 Watts.
Old 06-16-2020, 12:05 PM
I thank you both for your replies. I guess I was overly optimistic! This little machine with its 12hp and hydro feels so strong, and the generator looks much larger than the very small chainsaw. But if it will only output 180 watts (or a few minutes before battery decline), then that is not enough. I guess the massive look of the starter generator is due to it strength as a starter, its dual purpose... or maybe just due to the fact that it was probably engineered and "overbuilt" in 1960. I HAVE been given an "almost running" Stihl (sp?) #350. Perhaps that is worth fixing.
Old 06-16-2020, 12:45 PM
There were/are gen sets available that ran off the PTO and frame mounted on the front via the QA setup.
I'd be in the market form one of them, or just go buy a portable gen-set and pull it around on a Cub Cart.
You guys get ice storms up that way and it would sure be handy for that in a pinch, could at least power your furnace to keep warm!!
Old 06-16-2020, 01:27 PM
Google says a stihl #350 is a back pack blower,
but I didn't dig deep.
If you were given a stihl, it is worth what you spend fixing it!!
They ain't a china knock off POS.
As far as a cub driven generator, these are fun to use, and they are in the vicinity of 4500 Watts.
'Course you have to run yer engine @ 3600 RPM's so it is not Honda quiet
Pincor:
