Something in the shifter on my 126 broke. I could still get it into all gears, but the shifter is loose and flops around. What is the most likely problem, and how much work should I expect to be involved in fixing this? Will the trans have to come out, or is there enough room with just the fender pan off? Obviously I will need to take it apart to see what broke, just trying to get some ideas first.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Pull your fenders, unbolt shifter. The forks bolt on and clamp to the rods. If they are loose and slip on the rods that is the problem. See if they can be tightened.
OH!.. If they just loosened up,. Position both forks to neutral position and verify its actually in neutral. The part where the shifter goes into the forks should be in alignment as well. Tighten them down to the rods. Reinstall shifter. It took me longer to unbolt my foot rests than to open shifter and repair
Pull the shift plate off the top of the transmission and see if the cup on the shift handle hasn't broken.
I had that happen to a 104 years ago. I brazed it back together and it's still in one piece. https://www.partstree.com/models/104...-mechanism-12/ |
Thanks guys. I don’t think I could be lucky enough for them to have just loosened up, but that would be nice. I’ll pull it apart tonight and take a look.
The handle is broken loose from the cup.
You have to be careful when welding this back up and be sure to get the handle in the correct orientation to the cup or the handle will more than likely hit the fender pan somewhere during the shift range. |
