Old 07-12-2020, 11:02 PM
Sebastion Sebastion is offline
Default Cub Cadet 3208 rear end & fluid
Hi all, New here as you can see. I recently traded my old boat for 4 Cub Cadets! to me it was worth it, I love boats and watercraft as my dad is a marine engineer but I do not have the free time to enjoy it. The Cub Cadets are a 3208, 2135, GT2550 and a 149. They all have issues and so did my boat so I'm in the plus since I have many uses for these when running. I currently I have an LT1024 I use for mowing 6 acres I was given that needed work and now runs like a champ.
My main project that I want to fix is the Cub cadet 3208, it will not move and has a bad leak at the rear axle. My main hope for this tractor is it came with a huge 48" snowblower that will save me so much time. The model number on that axle is 618-3194 I was told to put oil in it and see if it spins whilst jacked up but the OEM oil is at a ridiculous price is there any alternatives in bulk I can buy?
After trying this I will determine whether I need a new rear end or a rebuild kit if any exist. I havent seen any forsale online. I have found an axle on eBay with the model 618-3221 Im not sure on compatibility. If any one can point me in the right direction it would be very helpful! I think I am going to be on this forum a long time since all them have issues.
Old 07-12-2020, 11:07 PM
CubDieselFan's Avatar
Welcome to Only Cub Cadets. Oak, our 3000 series expert will chime in on your issues.
Old 07-13-2020, 11:39 PM
Can you post a pic up of the rear? They used the aluminum rear in the early 3208's and then switched to cast iron. Both used the locking differential so that may be an issue too.
Here is an aluminum rear that I re-sealed. This one did not have the locking differential.
https://www.onlycubcadets.net/forum/...ad.php?t=33446
Lets see what you have and then we can go from there.
Old 07-14-2020, 08:15 AM
First, welcome to OCC..............
Per the Owners Manual, Cub Cadet recommends this fluid......
Old 07-15-2020, 06:30 PM
Old 07-15-2020, 06:42 PM
Thanks, I posted above the photos I took, My 3208 has a locking differential. I also added a few more to an album on my account. I was also looking at oils to use other then oem and wandered if Traveller Premium Universal Tractor Trans/Hydraulic Fluid would be alright. My first test will be to just see if it spins when I add fluid which I know will leak out. I can atleast get that in a town somewhat close by.
I keep saying its a 3208, it has no stickers visible and I do not see a factory stamp. I am going off from it has the Kawasaki FD620D liquid cooled motor. if anyone knows where a frame tag is please let me know.
Old 07-15-2020, 07:13 PM
ejl6658 ejl6658 is offline
Model and serial tag should be on the right side of the frame below the engine compartment side cover. If the tag isn't there you could have a 3205 or a 3208 as both had differential lock, aluminum differential, and the Kawasaki 20hp engine. Based on the pics I would say you need to tear into the differential and replace at least the seals on the inner axle bearing blocks which is why you are loosing fluid, but I would also replace both seals on the outer bearing blocks as well while you had it apart. See Oak's link posted above. The attached link is the spec sheets for the 3000 series from 1998-2003. I don't think you'll be able to tell from it whether you a 3205 or 3208 but it has good info. https://www.cubcadetpartsnmore.com/c...et-spec-sheets
Old 03-28-2021, 12:46 PM
bbrangle bbrangle is offline
Default 2005 GT3200 Hydraulic fades
I bought a 2005 CC GT3200 with about 500 hours on it. Question...I am having issues with my hydraulic drive. When I start the tractor and began to engage forward the movement is slow and weak. After about 10-15 minutes, and assuming the fluid is warmed up, the movement is fine. Forward and backward work as they should. When there is sluggishness/weakness, the tractor seems to loose engagement when I release the accelerator pedal. Instead of stopping, the tractor continues to roll and almost freefalls going down a hill. I replaced the fluid and filter, made sure all connections were not leaking and the problem persists. No leaking anywhere. I'm at a loss in what to do. If anyone has any thoughts, please advise. thank you.
Old 03-28-2021, 12:58 PM
Probably not the issue but have you checked the hydro release valve on the bottom of the hydro? It is #29 in the attached link.
https://www.cubcadet.com/en_US/conte...a5722faac43e/y
Old 03-28-2021, 08:35 PM
I agree with Oak that is sounds like the hydro is in bypass. The pull rod on the rear plate levers a flapper plate that pushes on the button of the hydro release valve. Make sure the flapper plate isn't bent causing the hydro to be in bypass
