Old 07-24-2020, 03:49 PM
bdr3949 bdr3949 is offline
Default Cub 122
why does my 122 internatioal cub cadet die when i unhook the Jumper cables. I have had the alternator rebuilt?
Old 07-24-2020, 04:25 PM
Billy-O's Avatar
Billy-O Billy-O is offline
You likely lost power to the coil when you removed the jumpers. Do you even have a battery in that tractor? A good one?
Plow blade
#2 Cart
QA36 snowthower
Old 07-24-2020, 05:18 PM
the battery that is in there is dead.
Old 07-24-2020, 06:10 PM
mortten mortten is offline
That would be why.
Doug
QA-36A
42" blade
Old 07-24-2020, 08:54 PM
Originally Posted by mortten View Post
That would be why.
Completely agree. It requires electric power from the battery to run. If it was a magneto, it would work but it's not.
Old 07-24-2020, 09:45 PM
thank you, I thought the alternator would generate enough voltage to keep it running
