Old 08-04-2020, 12:22 AM
Hart_Staff21 Hart_Staff21 is offline
Default CC 2082 No electricity to PTO
I just installed a new PTO on my cub cadet 2082. I am getting zero volts from the wire. I checked the switch by engaging the switch and trying to start the engine. Won't start. I have checked the PTO clutch and I am getting a good reading there and at the battery. Is there an in-line fuse that might be blown? Any thoughts on what else might be the problem?
Old 08-04-2020, 08:28 AM
There could be a number of things that will cause this. I would start with the most obvious and look at the Seat Switch. In normal operation, someone has to be in the seat for the PTO to engage. There are two Seat Switches. One for the start circuit (YEL & ORG wires) and one for the PTO circuit ( VIO & BLK wires). IF....you have DVM (or VOM) check and see if you have continuity through the switch when the plunger is depressed. Report back.
