Old 12-01-2020, 11:54 AM
ironman's Avatar
ironman ironman is offline
Default Need paint stripper advice
Prior to 2019 most brands of paint strippers worked decently because they contained methylene chloride. Then Big Brother banned the ingredient from use in paint strippers available to consumer sales, and now the "hardware store" variety of paint strippers are all pretty much a waste of money.
I am starting a new restoration project and was hoping someone could suggest a brand or source for a stripper that can do some serious removal of automotive/industrial type paint on metal. I don't mean that citrus crap for kitchen cabinets.
Thanks in advance for any good info.
Old 12-01-2020, 01:40 PM
longislandcubs longislandcubs is offline
I had a multi-layer of spray as well as the original paint on a set of Original fenders...I used a product from Total Boat. Its called Totalstrip Marine Paint & Varnish Remover. I think the web site was called TotalBoat, it was a bit pricey but I just couldn't find anything at the box stores that worked...
Old 12-01-2020, 03:12 PM
ironman's Avatar
Thanks for the lead, but Are you saying that it worked great or so-so.
I checked their web site, they seem to indicate use for varnished wood on boats.
Price is not bad for a whole gallon, if it does the job.
Old 12-01-2020, 04:01 PM
spndncash spndncash is offline
I have used totalboat it worked well on the paint and so-so on powdercoat. It took several coats on the powder coat but it did come off. second choice I have used aircraft remover and it was about the same result.
I dont know where you are in PA but I have 9/10 of a gallon of Citristrip that you can have because it is utterly useless!
I look for products not available in California then I know they will work! haha
Old 12-01-2020, 05:16 PM
I have tried all of the box store products. Nothing works like the pre-regulation paint strippers. The TotalBoat product worked the best for removing paint off of old, multi-layer projects I have worked on. I did find that you have to keep it off of rubber or plastic as it did soften them up.
Old 12-01-2020, 06:07 PM
ironman's Avatar
OK Guys, I will give the TotalBoat a shot. I had never heard of it before so it will be a leap of faith on you guys. Thanks for your input.
