Old 12-30-2020, 08:00 PM
CubbyRI CubbyRI is offline
Default Plow lift handle bracket question
Hi All, got the plow on tonight but the lift handle bracket doesnt allow the foot pedal to go back against the frame. Looks like it might be bent up too much? I still framed some plow videos to try and get a close up but no luck. I can just heat and bend the fingers out but just in case I am missing something, throwing it up here first:
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 12-30-2020, 08:11 PM
That one is for the 1x6 1x7 models, it will still work but you will need a longer bolt and some washers to space the the foot rest away from the frame.
Old 12-30-2020, 08:14 PM
cool that explains it then! I can always bend those tabs away too I would think so the foot rest can then move inward where it belongs...
Old 12-30-2020, 08:19 PM
The tabs are supposed to be there, a bolt goes through the bracket to keep it from coming off.
Old 12-30-2020, 08:35 PM
Grind the corners off the tabs to clear the foot fest or shave a little off the end of the it,
Old 12-30-2020, 08:52 PM
What is he going to do when the forks for the plow frame are there?
There is a manual that shows how it mounts.
