Old 08-15-2010, 04:16 PM
river_guy river_guy is offline
Default Spindel Bearing for a 42" 122 Deck
I'm going to be replaceing all the bearings in my deck. The mower is a 122, and it has a 42" deck. I wanted to see if anyone had some tricks, or if there was a good how to. It's always nice to use tricks that someone else has figured out. I did some searching, but did not find anything.
Old 08-16-2010, 10:34 PM
Ash_129 Ash_129 is offline
I have replace bearings, removed old races and pressed in new, and replaced end seals in the style of mandrels that you are talking about. I even had to re-center and weld/repair a broken shaft for one. (Shaft was broke away at the factory weld of the underside blade/bearing cup.)
If there is anything specific that you have a question about regarding rebuilding this style of mandrel, then fire away.
Cheers
Old 08-16-2010, 10:38 PM
I will be starting dissassmebly tomarrow. I'm sure after that I will have lots of questions.
