Last summer a friend of mine approached me with a Cub Cadet that was about to go to the junkyard and I said absolutely sure I'll come pick it up. It just needs a few necessities like a fuel tank starter generator regulator battery seat, and a couple minor other things. It's a spring project to get running again and get the hydraulic lift working.
1614294978742.jpg Also picked up another narrow frame last week, actually it just kind of got dropped off. Of course I thought I was going to use it for parts on the 149, but I think it'll make a nice machine to hook another Implement on. Turns out it's in better shape than I thought it's just a plain Jane though no attachments or features This one was also delivered with a parts 1720 with a mower deck. Don't know what I'm going to do with that yet.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
Certainly glad to hear you were able to save it from needlessly becoming crushed and/or shredded scrap. Nicely done sir, I have three wide frames and love them.
Nice save!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
I believe that once you give them what they need to live again, they will repay you for your help. Somehow, machines, especially older ones, know when they've been given a second chance and are usually very grateful for it
It all started with a little 122...... |
Yes, they like some maintenance! I will post some pictures of these here later. The wf is a 149, nf is a 127, second one in my fleet.
This is the second 127 I acquired several weeks ago. It is a mid Feb 1970. It has very few options, but will be a great tractor for around the yard. This will need a new wire harness at some time, and a fuel tank in progress. Hydro lever is seized somewhere. The tires on the rear and front are in excellent shape for what I think are the factory installed. It has some mouse debris in the engine under the tins. The po has a piece of wire jumped from the back side of the electric lift option connector to the batt terminal on the switch, not sure why.
. Seems this would be bad for points/coil, because the power would never be removed.20210306_rhside1.jpg20210306_090710Customocc.jpg 20210224_190317Customocc.jpg20210306_090247Customocc.jpg
It has a vertical m-18. carb, mag,starter, charging system, heads, and other parts are usable on a horizontal engine. Also the deck has the new style tapered aluminum spindle housings that are a bolt in upgrade for stamped water pump style housings. Also the anti-scalp wheels can be retrofitted to the early 50A and50 C decks without them. Might consider purchasing 1 lotto ticket---
Thank you for the tips. I will get around to posting a couple pictures of the cylinder walls and advice on that, because yes I would spend the time to rebuild that and a wire harness. Yes, the 1720 is a parts unit. motor is an MV18S and hydro gear 326769.
The rear transmission was loose to the frame so I split that to replace the cork gasket and replace the driveshaft. And the hydro linkage needs to be tightened up. Here are some pictures of the split tractor.
top_rear_LH hydro 7_17_21.jpg lh side split 7_17_21.jpg rh side split rear 7_17_21.jpg LH hydo side 7_17_21.jpg
