Hello ! So I recently found an absolute amazing condition model 1650! Strong K341, and boy is it a pounder. So,.....
Serial number: 2050670u6549. Its a very late model. My question is, at what Serial number did the manufacturer change the brake pedal return spring location? All the QL's I've owned all had the 90* angle bracket welded on the right inside of the frame (sitting in the seat) . My "new" 1650 has a long spring on the left side at the pedal and routs back to the front "Z" transmission mount bracket. My 1650 has internal brake pucks. Thanks!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
These images may help.
The parts breakdown doesn’t show a serial number. It says 2 springs were used. A long and a short. My 1250 609462 has the long one. That’s May of 1977.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
My 1650 only has the long spring, apparently. This is my first 16hp single cylinder and its a little "more", lol, than the 4's I have been use to. Shakes like nothing I seen. Probably gonna go with steel engine mounts in the near future.
On My 782 they used a longer bolt through the fame on that little transmission brace. Then a lock nut but left only threaded on enough to lock. Then it hooks on there instead of just hooking on the brace.
Ahhh, I see how the spring attatches to the brake rod, via the little tab! Thank you!
Yes, lol, here's the whole serial number...seems i forgot some digits . 205067U654912 My 1650, I noticed, has the aluminum rear axel carriers, aluminum upper and lower grill housings, and 1" front wheel spindles.
