The 149 died in my yard today. The engine doesn't have any trouble turning over, but it just won't start. Checked the plug and that looks good. It did briefly start but only on full choke for a few seconds. When looking at the front end while turning the key it looked like the flywheel was a little lop-sided, but it didn't seem to be bothering the belt any. I used a meter and was getting a good read out of the ignition coil so I'm at a loss. It would start making a whining sound that seemed to be originating from under the control panel if I had the key turned for too long.
Any ideas? |
I also poured a drop of seafoam down the spark plug hole and got a puff of white smoke out of the exhaust when I tried starting it so compression seems to be alright
I could be wrong, but, Those two statements make me think I would look at the fuel system first. |
I've had some issues with the carb in the past, I wonder if that could be it. |
Problem solved - took off the air filter assembly to get at the sediment bowl, which had quite a bit of dirt in it. The float had also come way off level and the needle float was jammed. Looks like cleaning that will be this weeks project but at least she started and is back in the garage. Thank you for the help, I'm still pretty new to all of this
An engine needs spark, fuel and compression to run.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
I have been coming across quite a few units lately, of all types, (i.e. mowers, tractors, etc) all with the same m.o.
They all have sat for a while, but not necessarily a long time, and they don't want to start for lack of fuel. I have found all to have stuck float needles that come unstuck with the slightest touch. None of these units had fuel pumps and the gravity pressure of fuel trying to enter the carb would not release the needle. Once unstuck, the needles remained free and the units all ran fine. I am suspecting it has something to do with the makeup of today's gasoline and wondering what additive would prevent the problem. |
