New here. I have removed the tranny and Sundstrand U15 hydro from a 1650 cub cadet.
Cannot get output of hydro motor to turn when powering input ccw. Question involves correct mounting of the gear charge pump. On one end of its casting is a flat spot. Does that flat point to swash pump actuator(speed control) or the other side. Have tried all combinations and non work so I want to be sure I have it correct so I can go on trouble shooting. Thanks, Jim in mich. |
I am not experienced enough in these units to answer your question. However, others here are, and should soon be along to help you.
In the meantime, here is a link to a service manual that may help you.... https://assets.danfoss.com/documents...7en-000101.pdf |
Service manual for 1650 page 2-44, flat side goes to right side of machine. This would be opposite swash control lever.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
Have you looked into the relief valves on top of the pump? If they aren't functional then the system won't build any pressure and the tractor won't move.
Also, its kinda a rare occurrence but, can you spin the output shaft on the pump? Or is it locked up?
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
Thanks for the replies.
I read the service manuals "right side" but that leaves the question of which is right side. Also confusing me is that detailed drawing of the unit clearly shows flat side on same side as swash actuator. Yes, I had both check valves repaired. Am interested in the bound-up question. Certainly not mechanically as I have inspected guts and all looks new. Cannot turn motor output by hand, but assumed that is because of spring pressure in piston assembly. I have been driving pump at 1000 rpm; today I plan to try 2000. Jim |
The right side of the unit is on the side opposite of the trunnion and hydro linkage. When you look at the pump from the front it'll be the left side. Another possibility I have just thought of is, maybe the charge pump has failed and just isn't functioning at all anymore. I do believe members here have had that issue in the past.
You may want to read this thread (to the end)....
https://www.onlycubcadets.net/forum/...ad.php?t=30840 |
