Ok I have about had it with this one. My cub sits outside and the choke and throttle cables are again stuck. Throttle cable broke off up at the lever.
Are there stainless cables I can attach to the CC throttle lever, or can these be covered in heat shrink or other tubing to keep the lube inside and the water outside? Ideas welcome!
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
Try searching push and pull cables in the marine industry....for boats. They do make stainless.
This is an example but I don't know if this fits: https://www.napaonline.com/en/p/BK_7...ng_dcoe_google Otherwise I would think about a storage shed or garage for the whole tractor, not just the cables.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
what he said....
K thanks, I will look at marine products. be nice if I could marry a marine cable to the OEM throttle lever and that should be doable.
Have you ever tried using "chain and cable spray" ? I believe it's made by " Lubriplate". It works great on motorcycle cables and chains. I also used it for my hood release cable for the car. Speedometer cable .
thanks gary I will add that to my spray cans shelf...
