Old 03-26-2022, 08:42 PM
Swartzzz Swartzzz is offline
Default CC 782 Throttle Link Return Spring
Is there somewhere I can find a part number for the throttle link return spring for my Cub Cadet and KT17?
Old 03-26-2022, 08:51 PM
Yes you can. What is the Kohler "Spec" number for your KT-17 ??
Old 03-26-2022, 08:53 PM
Where would one find that number? On the side?
Old 03-27-2022, 06:44 AM
(A) The "spec" is located on the Engine Model/Serial tag. It is located on the top of the engine, near the Breather under the Carb. It is a five digit number starting with 24, ie: 24XXX.
(B) Either copy down or post a picture of the Model/Serial Tag of the tractor Chassis. That is located near the LH Foot Pedal.
Old 03-27-2022, 09:43 AM
I am learning so much about this thing. When my dad and I bought it, we put it in the shed, I ended up having a family, and never touched it for 15yrs. Machine started up right away after jumping it. Shocked really.
I have learned that this is an International Harvester version, not MTD, as well as it appears that I have a Series I KT17. Good news is that my yard is flat!
The oil plug I read means something. Just curious what your thoughts are.
Also, it appears that the original owner added a performance intake, as he drilled a hole in the air filter cap and filter metal piece!
Old 03-27-2022, 09:51 AM
It would appear that my tractor: 689547, is one of the last 5000 of the 29,427 built.
First 782: 665001
Last 782: 694428
Everything about this tractor makes me believe that this engine is a Series 1. But I should probably dig in a bit to see what I can see on the Kohler side of things. Perhaps this was an engine replacement.
