As I’ve finally gotten my tractor running pretty well I’ve began tackling the mower deck that I got with it. I got the blades off after lots of PB blaster and a very good impact. I’ve got the spindles apart from the deck and I’ve began disassembling them, however I’m confused on how to check the condition of the spindles and bearings. I’ve got the pulley detached, the spindle is in two pieces. I see two rubber seals on each end of the “main” spindle piece, and that’s as far as I’ve gotten. Is there a way to further disassemble these? Replace seals, bearings etc? How do I tell if a replacement spindle is needed? If one is needed how do I find a replacement?
Not knowing what model your deck is off makes it a little difficult but my 50" deck the spindles have the a seal top and bottom thence bearings top and bottom , if bearings are rattly or grate replace them just knock them out and take to a bearing supplier to get same type and seals and press back in , easy as
I have rebuilt one of my spindles Oz
My wife says I do not listen , at least I think thats what she said |
Sorry, I forgot to mention that. It’s a Cub Cadet 147. The bearings I think are in the middle of the spindle? The seals seem to be in the way but I’m not sure how to get those out. I’m scared of ripping one and not being able to find a replacement.
You might try this. It is a link to the IH Parts Manual for the IH built mower decks. Since you have a 48" deck, please know there are about 3 or 4 Generations of this deck. Look at each of the 48" generations to see what resembles yours. From there, it will show the parts for that generation, what was used, and the order installed. See link....... IH Decks
If you are lucky, you have the later version of spindles with aluminum housings and use common taper roller bearings like automobiles front spindles, before they went to front wheel drive.
Bearings and races are dirt cheap. If they were quiet and not loose, I'd not bother with them. Do understand if the pulley and blade are not in place, they will seem "loose".
