Old 04-22-2022, 04:39 PM
bote110 bote110 is offline
Default Grease fitting front wheel XT1
I was doing some greasing for the season and the fitting fell out on my xt1 lt 50 front wheel . is there a way to replace this or do I have to buy a new rim. Any special tool ?? Was going to try to tap it but no room I also notice it looks like zerk fitting push in ?? Has anyone ever replace this fitting and how ??
Old 04-22-2022, 06:55 PM
EternalArianne EternalArianne is offline
I had one of the zerks on my deck spindles pop out when I was greasing it. The threads on the zerk itself were stripped smooth. They sell them at the hardware store for cheap, should just screw in.
Old 04-22-2022, 07:47 PM
I was told they might be push in type I didn't see any threads on the rim and cub cadet INC. say it's a 3/16 push in. Can't seam to find a tap short enough to fit in unless some one found a way to thread it . I have a friend that owns a motor bike shop might take to him and see if he has something if not hate to have to buy a new rim when this rim is still good .
Old 04-22-2022, 08:16 PM
If you can't tap it to accept the screw type, maybe replace just the wheel bearing? I've seen the bearings by themselves that have the zerk attached. Sorry I can't be much help, the XT1 is fairly new and had many different variants on parts, etc.
Old 04-22-2022, 08:48 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
MTD has been using push in zerks for years.
JD x475
Old 04-22-2022, 10:14 PM
Don't know if this is possible because I have not seen exactly what you
are dealing with, but. When I have run across push in zerks I have taken
the wheel and bearing apart and hand greased everything and put it back
together. Was once a time when zerks were not there and we rolled
bearings in greasy palms to lube them up.
Ken
