My 2146 backfires thru the exhaust when it's shut off after mowing the lawn.
Any cure for it? it's been doing it since my dad left it to me.
cub cadet 71 that my pop pop got new and gave me in 85......restoration just started cub cadet 100......was a friends grandfathers, given to me in 93.. restoration almost finished cub cadet 72, 150 dollar craigslist find, 38" deck, worker cub cadet 127 basketcase, my dad bought in 84 cub cadet 71 beauty (formerly johncub7172's) cub cadet 123, craigslist find
Are you letting engine idle down a minute or two before shutting off. That usually helps. Also, You could be running too hot or lean.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I've got 2 Kohler Command Pro's that are frequent backfire offenders. I just blip the throttle up a bit as I shut off the IGN. Works every time.
Turn it off from approx half throttle that will stop your problem
Oz
My wife says I do not listen , at least I think thats what she said |
was only idling it down for about 20 seconds. Yesterday i let it idle for about 2 minutes then drove it at idle back into the shed and it did not backfire. Come to think of it Dad complained of it doing this to the cub cadet dealer when it was under warranty and they did not give him an explanation, heck they picked up the tractor once and brought it back with zipties holding the deck up on one side. I buy my parts online now, not giving then any money.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
One hand on the throttle and one on the key, go wide open at the same time you turn it off.
