Greetings,
I figured I'd make a new thread to document the 984's return to service after sitting almost 20 years. Attached is the tractor how I found it, then it's status last night. Rear tires are off as I cleaned/am painting the rims in preparation for new Carlisle Multi Trac CS Lawn & Garden Tires (Rear - 26X1200-12 LRB 4PLY; Front - 18X850-8 LRD 8PLY). I plan on pressure washing the rest of the tractor and getting tires on it before any real use. The cab (headliner), fuel tank, and fuel lines were in sad shape when I got it. I also have some wiring "modifications" to undo in the immediate future. The engine is a Liminar/Onan Performer 20 crate engine put in right before the tractor was parked. ![]()
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
For reference: https://www.onlycubcadets.net/forum/...ad.php?t=60031
Love your rare 984.
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Thanks. I think it'll look cool next to the yellow 782, which I'm also working on.
Back on track -- canvas white is not the near match I read it to be, unless it dries significantly darker.
![]() Pressure washed, wire wheeled, wiped down, and primed the rear rims. New tires arrived today, so hopefully I can finish paint tonight and mount tomorrow after work. ![]()
![]() Quote:
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
