Old 06-03-2022, 12:45 PM
CubbyRI CubbyRI is offline
Default Charging Volts 15.2 too high?
Hi All, started my cub 100 just to charge it and decided to check the volts when running see if its chargin. Got 15.2+ is that too high, or ok?
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 06-03-2022, 01:01 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Smile
I'd say, yes-especially in the warmer months. You can tolerate a bit more voltage in the cold weather, but during the warmer months, this can lead to a overheated battery, and the electrolyte being boiled out of the battery. Better to see the running voltage at full engine speed 14.2-14.5 Volts.
Old 06-03-2022, 01:06 PM
ok thanks... whats the fix, can the regulator be adjusted?
Old 06-03-2022, 01:52 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Start with making sure the wire connections to battery, SG and regulator are nice, bright and tight. Including ground. And make sure the regulator is grounded properly. See what happens.
Plow blade
#2 Cart
QA36 snowthower
