Old 06-10-2022, 09:47 PM
EternalArianne EternalArianne is offline
Default Best way to keep a string trimmer cool?
I was over at my grandmother-in-law's place today doing some weed trimming. It's a fairly large lot with lots of trees and fences to trim around. After about an hour of solid work, I shut off the trimmer to change the line. Went to crank it back up and it would idle but shut off when I gave it the throttle. After I let it sit for a good 30 minutes, it worked fine again. So I assume it overheated?
This doesn't seem to be just this particular trimmer, as I had a different one the last time I did this at her property. Except that trimmer overheated after only 30 minutes of runtime.
Is there a good way to keep these things cool? Or is it just the consumer grade equipment isn't meant for long sessions, and I should get a commercial grade unit?
Old 06-11-2022, 11:05 AM
Farmall450's Avatar
Buy a $200 ECHO SRM-225, problems solved.
https://www.farmandfleet.com/product...n-trimmer.html
Old 06-11-2022, 01:28 PM
Echo is the same brand my local repair shop advertises as well. Maybe once my Cub Cadet trimmer dies (which I got for free btw), I might look into a professional grade trimmer.
Old 06-12-2022, 11:16 AM
Farmall450's Avatar
ECHO makes a premium product in Lake Zurich, IL. And, they have a 5 year consumer warranty.
Old 06-12-2022, 12:40 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Sounds like vapor lock. Carburetor gets hot when shut down because there is no fuel and air flow to cool off. Try idling a moment before hitting kill. If that doesn't work, consider richen the mixture a little to run cooler.
Plow blade
#2 Cart
QA36 snowthower
Old 06-12-2022, 06:43 PM
Originally Posted by Billy-O View Post
Sounds like vapor lock. Carburetor gets hot when shut down because there is no fuel and air flow to cool off. Try idling a moment before hitting kill. Of that doesn't work, consider richen the mixture a little to run cooler.
I'll try the idle trick. This trimmer calls for 40:1 ratio, which is what I've been using in it (the premix canned stuff).
